X300 ecu
Old May 13, 2012 | 10:53 AM
CJNetrider's Avatar
Default X300 ecu
Hi all, had an issue with my x300 cutting out the other day. At first I thought it was lack of fuel due to the gauge not being true. However, managed to get it running although it was sluggish over 2000prm. Following day, went to start and absolutely nothing. No crank, zippo. Cheched for water in looms, luggage and footwell where I found the culprit. The ecu showed signs of water damage and when opened, one of the clips from the multi-plugs had come off. Anyone know the best place to get a replacement? Had a quick look on Ebay but cannot see anythink in uk that matches the part number LNA141OBE/211.
Suggestions much appreciated!
Cj
Old May 15, 2012 | 09:08 AM
CJNetrider's Avatar
Maybe a lot harder to get hold of than originally thought then.
Would anyone know if the numbers have to match exactly? Including the letters that is? I've had mixed responses on this when calling breakers.. one has said it can affect revs, etc.. others say its just a slightly newer model and ofc I don't want to take a chance
mat32essex
Oct 3, 2015 04:12 PM
Johncy2000
Oct 2, 2015 01:05 AM
280zx-turbo
Sep 28, 2015 04:37 AM
42Ajd
Sep 26, 2015 07:04 PM
