X300 getrag 290 clutch master cylinder
Old Feb 21, 2015 | 12:06 PM
Paulofvfreitas's Avatar
Default X300 getrag 290 clutch master cylinder
Hello,
Do you know where to buy reseal/rebuild clutch master cylinders for a 96 3.2 x300 manual?
Or a interchageable part? I just found out that a xj40 part will fit but needs some other parts relocating. http://www.xj40.com/viewtopic.php?f=...95712&start=10
Has any of you guys been throught this or compared older parts with the x300 ones to check differences.
Old Feb 21, 2015 | 12:44 PM
plums's Avatar
87-91 Toyota Supra Turbo used the same transmission. Maybe they used the same
master cylinder.
Toyota is usually much better at offering rebuild parts as opposed to "assemblies".
Old Feb 21, 2015 | 01:29 PM
master cylinder.
Thanks will try to find the partnumber
I have already found that the e34 alpina and the holden commodorees v8 used the same getrag290 but cant seem to find any parts.
Best regards
Old Feb 21, 2015 | 01:33 PM
Just searched but cant seem to find a supra with the getrag 290 , SUPRA 5 speed vs SUPRA 6 speed. [Archive] - PerformanceForums
Only the mk4 seems to have a getrag but a sixspeed
Old Feb 21, 2015 | 01:44 PM
Kleman's Avatar
Paulo,
The master clutch cylinder is part nr. CCC6760 which, according to the Jaguar Heritage, is used on the XJ40, both 6 cyl and V12, and the X300.
The fact that Naki (from the XJ40 forum) is having a problem with part numbers is not a good sign. Naki is very knowledgeable on XJ40 and X300.
Would it be an idea to ask him how he ended up by solving it? He is a very helpful person.
Jorge
Old Feb 21, 2015 | 01:51 PM
Thanks jorge i will try to speak to him
Old Feb 21, 2015 | 02:27 PM
plums's Avatar
Toyota had an internal name for it. The above models all used that transmission
if equipped with the 5 speed manual.
Delta66
Oct 4, 2015 05:40 PM
mat32essex
Oct 3, 2015 04:12 PM
baskervillema
Oct 1, 2015 01:59 AM
42Ajd
Sep 26, 2015 07:04 PM
