X300 inner tie/track rods
Old Dec 4, 2020 | 05:00 PM
BobbyDing's Avatar
Default X300 inner tie/track rods
Hi all, we've discovered at least on one side the inner tie rod is worn out. The ball joint rattles around inside the socket. I've already removed it from the car. But from what I've read Jaguar wants you (me) to replace the entire rack that would already include new rod ends. However I have also read where some folks have replaced them separately. None of my usual parts suppliers carry them for this car. Besides ebay, who else carries the inner rod ends in the US?
Thanks,
Bobby
Old Dec 4, 2020 | 06:45 PM
katar83's Avatar
SNG Barrat will have them in stock, might be part MNC3901AD if I remember it right,
Old Dec 5, 2020 | 01:29 PM
BobbyDing's Avatar
Why yes they do. Thank you!
I've search through the online service manual and have not found any torque specs for installing these with the tubular tool. I'll apply some loctite. Any suggestions on a good install torque?
Bobby
Old Dec 6, 2020 | 05:38 AM
countyjag's Avatar
It may just be a trick of the camera, but your track rod looks slightly bent.
Old Dec 9, 2020 | 01:55 PM
BobbyDing's Avatar
I had to go back and check it. The rod is definitely slightly bent. I didn't notice that till you pointed it out. That one is being replaced already. But I do need to go back and check the other side now.
Anybody know what the torque spec should be for the inner tie rod to the rack?
Bobby
Old Dec 9, 2020 | 03:41 PM
b1mcp's Avatar
I've attached the relevant page from the ZF manual with the Torque specs for the Tie Rods.
I think you will have type 7852 - but check plate on the rack.
Don't forget to counter-hold the rack while tightening!
File Type: pdf
Old Dec 10, 2020 | 03:57 PM
BobbyDing's Avatar
Just the info I required. I have located the flat on the rack to use for counter holding it.
Thank you,
Bobby
Pirk
Aug 14, 2020 09:21 AM
Jag4
Nov 3, 2019 02:10 AM
Devin Roland
Jun 28, 2017 07:13 PM
nickxj6
Mar 18, 2015 05:34 PM
mhamilton
Dec 25, 2013 12:33 PM
