X300 not start
Old Apr 20, 2014 | 01:11 PM
Dave2254's Avatar
Default X300 not start
Hi guys i have a 1996 X300 it was starting fine up until last week. I started it friday and everything was fine saturday morning it turns over but just wont fire start!! I suspect a fuel blockage, located the fuel filter but finding it awkward to remove.
Any help will be much appritated as its got its mot in a week!!
Kind Regards
Dave
Old Apr 20, 2014 | 03:43 PM
sogood's Avatar
First and simplest check is the battery. Anything below optimum power can cause your car not to start. Have you tried a jump start, connected to the battery, not the terminal under the bonnet.
Before going in at the deep end and removing the fuel filter, check for a good spark on each plug. Removing the filter is a bitch of a job, inaccessible, with corroded pipes, nuts and connectors doesn't help.
Others will chime in.
Old Apr 20, 2014 | 04:14 PM
Dave2254's Avatar
I have changed the battery when i try to start the engine the battery charge needle goes into the red and the rpm stays at 0.
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
AL NZ
Sep 4, 2015 08:39 PM
