X300 Steering
Old Nov 30, 2010 | 01:16 PM
holybananas's Avatar
Default X300 Steering
Hey Guys,
Just in the last day my 1995 Jaguar XJ6 started making noise when turning, as well as idling. You can hear odd sounds when it's idling and if you turn the wheel while parked you can hear squeaky weird noises, as with driving.
Could this just be low Steering Wheel Fluid? Any ideas?
Old Dec 1, 2010 | 03:49 AM
Probably STALE fluid. I change mine every 2 years, ALL the Jags, and NEVER use ATF, only "power steer fluid/oil", and no noises.
The power steer pump on the X300 is a ZF aluminium unit, and is prone to wear if the fluid is neglected.
I would change the fluid with a proper power steer fluid, syringe the old junk out of the container, put in the new fluid, run for 2 days, do it again, and again, and again until what is in the container is nice and fresh and CLEAN, you just might, IF YOU ARE LUCKY, save your pump and your rack.
Old Dec 1, 2010 | 08:42 PM
smartobject's Avatar
Default Check fluid
Grant's advice sounds good, get some good, clean fluid in there.
Mine will sometimes make noise if the level is low -- fixed that though with extra clamps on the hoses, so they don;t leak.
Cheers,
Lee Shelton
95 XJ6 Memphis
Delta66
Oct 4, 2015 05:40 PM
mat32essex
Oct 3, 2015 04:12 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
280zx-turbo
Sep 28, 2015 04:37 AM
