x300no spark
Old Jun 16, 2013 | 07:28 AM
tony guy's Avatar
Default x300no spark
My x300 still having problems with no spark took out cas and it was dirty and bit of rust on end cleaned it still no spark is there any thing else to try before I replace it any suggestions welcome !!!!!!!
Old Jun 16, 2013 | 09:04 AM
Doug's Avatar
I'm afraid your posting isn't very clear.
However failed crankshaft sensors are common "no spark" culprits. If the tach needle doesn't bounce a bit when you crank the engine, that confirms it.
Old Jun 16, 2013 | 09:25 AM
tony guy's Avatar
Thank you will get new crankshaft sensor and hopefully that will fix problem
Old Jun 18, 2013 | 09:26 AM
tony guy's Avatar
Hi just to thank you all for advice put new cas on car and started first time
Thamks again Tony
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
LilaJagHubby
Oct 6, 2015 02:56 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
hoodun
Oct 2, 2015 02:06 AM
