XJ6 1996 Check Engine Light question.
Old Jul 1, 2009 | 07:46 PM
GTBentley85's Avatar
Default XJ6 1996 Check Engine Light question.
hello everyone, I own a 1996 XJ6 jaguar. Overall a very nice car. I was at a local jag shop today because the other day my car was misfiring, I couldnt get the car past 50mph and it would jerk like crazy. Then when I reved the engine it would make loud popping sound from under the hood. So my check engine light came on as soon as that happened, and off I went the next day to a local jaguar repair shop. The mechanic there hooked up his scanner and told me that I had a misfire in 3 cylinders which are 3 4 and 5. So I left there and went to a friends house who has the same scanner as he was using which was the Innova 3110 and when we hooked it up I only saw 1 misfire code on there which read P0303 detected. Can anyone tell me if this code stands for 3 misfires, or is it just one. Thank you.
Old Jul 1, 2009 | 10:07 PM
sparkenzap's Avatar
That code is misfire on Cylinder 3. However, suspect there is misfire on more than 1 cylinder for misfiring as bad as you describe.
Old Jul 2, 2009 | 07:51 AM
thanks for the quick reply, how would I kow for sure if its more than one misfiring? I should test each coil with a tester right?
Old Jul 2, 2009 | 05:28 PM
sparkenzap's Avatar
Swap coils and see if code follows coil, or stays with cylinder. P030X code, X signifies cylinder # from the front.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
rusty37
Jun 7, 2016 04:43 PM
big d
Sep 3, 2015 07:37 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
