xj6 grinding noise
Old Jan 14, 2010 | 11:38 AM
jhxj6's Avatar
Default xj6 grinding noise
when if first bought my 96 xj6 it made a little bit of a grinding noise on startup but only sometimes. i've owned it for about four months and it now happens every time i start it and even when im driving. its not very loud you have to listen to it but its definetly there. what would it be?
________
Voyeur Russian
Old Jan 14, 2010 | 12:00 PM
ken@britishparts.com's Avatar
My guess would be upper timing chain tensioner.
Old Jan 14, 2010 | 06:25 PM
panchostatus's Avatar
agreed. sounds like upper chain tensioner. the tensioner is hydraulic valve operated and they do tend to age a little less than gracefully and cause a slight slapping effect of the chain on the dampers. an easy replacement to your benefit though.
this guy with the two bolts on it
Old Jan 14, 2010 | 10:56 PM
jhxj6's Avatar
thanks guys for the info
________
Arizona dispensary
Old Jan 15, 2010 | 09:33 AM
Part is here:
http://www.motorcarsltd.com/NBC2031AA.html
Old Jan 15, 2010 | 07:31 PM
correct!
Old Sep 24, 2019 | 10:59 AM
High123bid's Avatar
Hi,
I have a pretty good oil leak from my 1994 XJ6 XJ40 upper tensioner. I can se that there is a gasket/O-ring kit. How do I pull the tensioner, please? I removed the two bolts and the tensioner is not moving an inch. More force or does the cover need to come off? What is the the re-tensioning procedure? Best regards, Bo Andersen
PMKimpton
Aug 3, 2019 08:22 PM
1LowCat
Feb 23, 2016 07:19 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
sawduster
Sep 11, 2015 10:02 PM
raulan
Sep 10, 2015 12:43 PM
