XJ6 power steering leak
Old Feb 23, 2010 | 11:11 PM
jhxj6's Avatar
Default XJ6 power steering leak
My xj6's power steering pump is leaking fluid and has been whining. Would the lucas power steering conditioner fix the leak? I've heard it has had really good results.
________
Weed Vaporizers
Old Feb 24, 2010 | 03:40 AM
Cadillac's Avatar
It seems lucas finally did something that is working ...Well, I think for the best results you need to have your steering rack replaced .
Old Feb 24, 2010 | 06:29 PM
carelm's Avatar
I used to have 96 XJ6 with a leaky rack and pinion. I used the lucas power steering conditioner and it did seem to help. As long as you continue to monitor the fluid you should be OK for a short term. As cadillac recommended you should get with a tech on a long term solution.
Mike
Old Feb 25, 2010 | 07:11 AM
jhxj6's Avatar
I replaced the rack and pinion about 4 months ago but this time my pump is leaking
________
Stock Picks
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
