XJ6 Suspension Overhaul
Old Jan 17, 2014 | 07:48 PM
windsorlad111's Avatar
Default XJ6 Suspension Overhaul
I love my XJ6, but sometimes think it is a little bit hard on bumps in the road. More than it should be. On flat roads, it's great.
What's the route to take for overhauling the suspension to get it back to its best?
Old Jan 17, 2014 | 10:00 PM
Doug's Avatar
Although these cars are often hard on suspension parts I'd begin with a careful inspection of the suspension, bushings in particular, before assuming you need an actual suspension 'overhaul'....which is quite an undertaking.
You might just need shocks, or shock bushings
Old Jan 17, 2014 | 11:37 PM
vandenplas408's Avatar
im in the process of making diy for the whole front suspension
new stabilizer links and bushing
all new wishbone (control arm) bushing (4x top and 2x lower , 2x lower )
new shocks
new lower shock bushing
new spring pan bolt
im reviving my 96 vanden plas should be the same for you
new stabilizer link top bolts
new bottom shock bolts
new top and bottom ball joints
new rack n pinion
new outer tie rod ends
new wheel bearings
Old Jan 18, 2014 | 04:24 AM
sogood's Avatar
If you have any clunks or knocks, then you're probably looking at suspension bushes. As you say that it just feels stiff or solid, then the shock absorbers/dampers may be shot. If they lose compression, they become ineffective and so the car just bounces on the coil springs. Alternatively, if they seize, then the ride will stiffen considerably.
You can jack up and support the car and place a trolley jack under the suspension carrier, jack it up and see how quickly or slowly the shock returns when you lower the jack. It should be a smooth consistent action, in keeping with the jack lowering.
If you do replace the shocks, remember that there are various options, with some leaning more towards a softer ride than others.
Plenty of info on here about rear suspension!!
Old Jan 18, 2014 | 07:14 AM
AllanG's Avatar
As you can see lots of different approaches one could take. It would be more helpful if you could describe the symptoms that you feel and/or hear.
Do you hear thumping/banging noises when going over bumps?
Does it happen while driving straight or only on curves?
Do you feel any vibration or buzzing though your steering wheel or the car seat?
Otherwise, as Doug suggested, a visual inspection should be carried out first. The rubber used in most of the suspension bushes/mounts will perish over time but is easy to spot if you get the car up in the air and use a pry bar to move various parts of the suspension.
If you are not hearing/feeling any knocks when going over bumps, my first thoughts would be to check the shocks.
sogood
Sep 15, 2015 07:35 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
avern1
Sep 8, 2015 06:25 PM
Harry Dredge
Sep 3, 2015 03:04 AM
