XJ6 USA model 4.0L
Old Feb 23, 2014 | 01:02 PM
pacopupus's Avatar
Default XJ6 USA model 4.0L
Hi guys. Sorry for my bad english. Thanks for let me into the Jaguar forum. I have 1996 Jaguar XJ6 4.0L Battery dead. Charged battery- everything comes on and powers up- turn the key... nothing. No click n signal ligth, no head ligth, no pullout the parking, no nothing. I use the key to lock the door and hold until the alarm activates. Im open my door and still the same problem.
Old Feb 23, 2014 | 01:50 PM
Welcome to the forum pacopupus,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 23, 2014 | 03:15 PM
RJ237's Avatar
Welcome to the forum. You charged the battery, but do you know for sure that it's good? You are going to need a multimeter to look for the problem. You should have around 12.5V at the battery if it's fully charged. Then have some one turn the key on and try to start while you watch the meter. If the voltage stays the same, you need to look further.
Does the red light for P show on the shift pattern? Try wiggling the gear shift and see if that helps. Next will be checking the main fuses that the pos. battery cable goes to, and after that the positive and ground connections in the engine bay.
You will need a wiring diagram but I don't think you can download until you have ten posts, so work on that.
rusty37
Apr 5, 2020 07:40 PM
JimMLiny
Sep 9, 2015 08:13 PM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
