XJR not charging and overheating
Old Nov 16, 2018 | 11:18 PM
Albin Sarndahl's Avatar
Default XJR not charging and overheating
Hi. I just bought a XJR -96 and on my way home with it the battery light came on, I drove on and 10 min after it was overheating. Can these issues be linked together? Now the battery is all drained. And the car won't start.
Old Nov 17, 2018 | 02:20 AM
SleekJag12's Avatar
Yes they could be. One belt drives both the alternator and the water pump. Maybe the belt broke or fell off. It should be easy to check. Hope you shut down soon enough to avoid anything bad. Sorry to hear of trouble first thing after the purchase, that's very unfortunate.
Old Nov 17, 2018 | 03:34 AM
The belt is still there but maybe it can be that anyway. The belt made some classic belt noise prior. It did turn but maybe not properly fast?
Old Nov 18, 2018 | 01:38 AM
SleekJag12's Avatar
If the belt seems ok and tight, then it could be the crankshaft pulley lamination failing, where the ring that turns the belt slips on the pulley. That usually causes some noise. See the last part of this current thread:
Bad Alternator
Or it could be a bad alternator! If power was lacking, perhaps the cooling fans couldn't run properly.
Was the charge gauge on the dash reading low even while at speed (I think that would trigger the battery light)? That would point more towards a bad alternator.
Old Nov 18, 2018 | 07:56 AM
Ric in RVA's Avatar
Test the Harmonic balancer by getting a dab of white paint lined up on the two parts of the pulley.
Drive the car and inspect. Did they move relative to one another? If so the pulley is bad.
Old Nov 23, 2018 | 01:04 AM
96x300's Avatar
Was this resolved? Curious minds want to know..
slburns538
51
Aug 16, 2019 10:49 PM
LoveHerTopless
Feb 8, 2018 11:47 PM
noterman
Dec 23, 2014 07:07 AM
EngineerReeves
Nov 10, 2013 01:34 AM
chuckbrantley
Nov 21, 2012 11:57 AM
