XJR oil filter
Old Mar 11, 2014 | 04:59 AM
Arnstein's Avatar
Default XJR oil filter
Hi. Because of very limited space,it seems impossible to change the oil filter on my -95 xjr 6. Will a special tool be needed or maybe VERY small strong hands?
Regards
Old Mar 11, 2014 | 06:24 AM
doc's Avatar
doc
I do it from under the car on a hoist easy as can be done from the top as well just not as easy
Old Mar 11, 2014 | 07:29 AM
Doug's Avatar
Regards
You're probably getting tangled up on that thin support rod which runs between the engine block and the inlet manifold.
What I do is remove the lower bolt (10mm wrench) and swing the support rod upward.
This allows much easier access to the filter
Old Mar 11, 2014 | 08:22 PM
BlackX300VDP's Avatar
Doug is right on with the advice. Moving the support is the only way on the supercharged engines.
Old Mar 22, 2014 | 01:01 PM
navcanman's Avatar
I have done a couple of oil changes without removing any support from underneath [car on ramps] just had to jostle around filter but found a way to both remove old and install new.......
Old Mar 23, 2014 | 04:00 AM
Arnstein's Avatar
I have changed the oil and filter (from under the car removing the support)..Thanks again for advise!
How many miles between oil / filter changes is recommended? I cannot find any advise on these intervals in the owners manuals.
Regards.
Old Mar 23, 2014 | 07:17 AM
The typical service interval for the X300 cars is every 7500 miles. There should be a link to maintenance schedules here on the forum. The Supercharged cars did get a slightly revised schedule. But all-in-all, the oil changes were recommended every 7500. Timing and distance is up to you but should not exceed 7500 miles or 6 months, "whichever comes first" (per Jaguar). I do mine once a year because I put much less than 7500 miles on in one year.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
pnwrs2000
Sep 3, 2015 11:55 AM
