XJR Thermosta
Old Jun 13, 2010 | 03:41 AM
wjbenit's Avatar
Default XJR Thermosta
Hi, I have recently purchased a 96 xjr which is great car, but have an issue in that the temperature gauge is very slow to move off cold and then will eventually get to about a quarter, but never really halfway. Reading can change fluctuate whilst driving too. I am leaning towards thermostat being U/S or a sensor ?
Also noticed that the engine fan is running when ignition is turned on and runs all the time, is this normal or has someone wired it to stop overheating ?
I am just used to my old XJ40 with the old viscous fan that engages when engine warms up.
Any help would be brilliant.
Old Jun 13, 2010 | 08:57 AM
Doug's Avatar
Agreed on the thermostat.
As for the electric fans there was a factory bulletin to change the wiring scheme. I can never remember if the operation you describe is "pre" or "post" the change. I'm pretty sure it was post change. Look for the two a/c pressure switches on the pipe near the firewall/bulkhead. If the wiring looks like it has been changed/bypassed, your XJR has had the wiring modofication.
Old Jun 13, 2010 | 12:22 PM
wjbenit's Avatar
Thanks for that Doug, helps a lot. I will get the thermostat changed.
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
JAMES1944
Sep 29, 2015 11:58 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
