******* rough idle and restricted mode
Old Sep 20, 2019 | 12:00 AM
Chopperscoot's Avatar
Default ******* rough idle and restricted mode
1999 x308 3.2
So far, plugs,packs, cps, lambda sensors,chains
******* thing runs sweet from cold then once warm the rough idle starts and restricted mode, leave over night and runs sweet from cold until warmed up. Please please help, wife hates me keep spending ( didn’t help when replied “ you have sanitary towels “) driving me crazy all I get after a while is snap-on code P0357 coil pack G
Old Sep 20, 2019 | 12:24 AM
M. Stojanovic's Avatar
Other than what you have replaced, the faults could be:
1. Fuel Pressure Regulator faulty or vacuum hose to it broken/leaking
2. Pack G is actually B3 (Left Bank); there could be a fault in the Ignition Module for the left bank, when it heats-up. The two ignition modules (left and right) are located next to the brake vacuum booster.
Old Sep 21, 2019 | 06:57 AM
Telphoto's Avatar
I had the same issues. Car ran fine for 10-15 minutes then ran rough, occasionally lurching on acceleration. New knock sensors cured the problem instantly and now runs like I dream, I'm so surprised that they made such a massive improvement.
Ktmscott
Sep 14, 2019 05:44 PM
KayScotts
Apr 29, 2016 01:26 PM
03blackjagstr
25
Jan 21, 2015 03:13 PM
Aug 28, 2010 10:07 AM
