01 xj8 maf sensor
Old May 22, 2012 | 09:15 AM
jtp2's Avatar
Default 01 xj8 maf sensor
i have a 01 xj8...4.0.....so i clean the maf with maf cleaner,replace filter......reconnect battery....no it runs worse.took it back to advance auto..the guy says i can check the maf with an ohm meter..but have no clue how to go about it..but i do know how to use a meter..any ideas
Old May 22, 2012 | 04:52 PM
H20boy's Avatar
hey JTP, i know that sounds like a general tech question 'MAF sensor check with an Ohm meter", but I really think you'll get alot of better advice, in addtiion to using a meter to check the MAF sensor, in your X308 subforum. Give it a shot, and good luck!
Old May 22, 2012 | 08:03 PM
sbreeden's Avatar
That would be the easiest way of determine if the MAF is out of specs is to find out the ohm's valus (resistance).
Since you are familar with a meter, all you need to do is a quick search to find the resistance values.
My quick search came up empty handed.
Disclaimer: !!! DO THIS AT YOUR OWN RISK!!!, had to say that.
Back in the 80's, this how my daddy taught me and never had a issue with damaging my cars. Now that I am a ASE tech, I use the proper tools to figure thing out (most of the times).
But, here is the side street mechanic way of testing the MAF. Start the car, then unplug the sensor, if the car idle jumps/engine smooth out, then you need to replace the MAF.
How did you clean the sensor? MAF cleaner? did you use a brush? If you use a brush most likely you destroyed it. Can not understand why there are youtube video with people clean MAF with brushes, the wire is so thin and can easy break with any type of pressure.
You should ONLY clean the MAF with the spray can cleaner, spray let dry, spray let dry, spray let dry, thats all.
SGB
Old May 25, 2012 | 08:36 PM
jtp2's Avatar
yes...i only used spray...no brush.does any1 know what readings i should expect on the ohm meter?
Old May 25, 2012 | 08:47 PM
Gus's Avatar
Gus
Before you get deep into this go back and check that the filter cover and MAFS are installed properly, plugs and all clamps/clips. At times when reinstalling the intake hose and air box we do not get it closed properly resulting in an air leak. It is critical that you have no leaks in the intake system. As for cleaning the MAFS you should only use the cleaner designated for it and whatever you do, you do not wipe or touch the sensor let it air dry.
xjrjag
Oct 24, 2024 03:09 PM
mrplow58
Jan 21, 2024 05:53 AM
caveforce
38
Nov 16, 2015 10:19 AM
Papelione
Sep 21, 2015 06:13 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
