02 XJ8 need a lil help
Old Nov 6, 2021 | 11:06 AM
02 jag's Avatar
Default 02 XJ8 need a lil help
Obd readers will not connect. restricted performance signal on. And mild engine vibration under 2000 rpms. Any ideas THANKS in advance for any help!
Old Nov 6, 2021 | 11:10 AM
Welcome to the forums 02 jag,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Nov 6, 2021 | 11:44 AM
Parker 7's Avatar
Someone found a pin bent in the OBD 2 connector
There ia a fuse that powers the OBD 2 connector which powers your device
See page 143
X300 01/E COVER (jagrepair.com)
# 4 / 5 amp LH heelboard fuse box point 12 square page 41
This fuse is hot at all time and directly wired to the battery cable
also # 10 / 5 amp RH heelboard fuse box at point 17 circle double hash page 45
The wiring guide is incomplete at this point but fuse # 10 should be dependent on the king relay for that fuse box to close , but..........
The first 9 fuses in the box are hot at all time and fuse 10 ,. 12 , 14 , 16 depend on the relay
The relay should be closed with the key in the run position and by removing the relay it should click back open
The relay is called the ignition positive relay back over on the LH heelboard fuse box according to the print on page 39
And this is where it is too complex a concept for me to effectively deal with , the wiring guide is bigger then me
Help
These king relays are probable related to your limp mode on the engine
John Lyle
US Northeast
Feb 15, 2018 03:10 PM
htretola
Nov 24, 2017 04:14 AM
JaguarCar
Nov 11, 2015 09:34 AM
Loopykums
Oct 18, 2014 01:33 PM
blue968
US Northeast
Mar 10, 2013 07:06 PM
