LH Low Beam not working - advice please
Old Nov 7, 2021 | 04:35 PM
ArizonaBrit's Avatar
Default LH Low Beam not working - advice please
Hi, I have a 2005 Jaguar Vanden Plas, and I found out that the driver side (LH) low beam is not working. I checked the fuse and it seems OK. I checked that there is voltage at the fuse level and there is 12v present. I bought replacement HID bulbs and after a great of hand scraping, cursing, etc. I got the old bulb out and inserted the new one, but it did not work. I checked the bulb on the other side and it's working ok. I understand there are some relays that are compatible in the fuse box. I understand looking at the wiring diagram there is something called a headlight leveling module which perhaps contains a ballast. I don't see where this is or if its easy to replace or even needs replacing. I am not even sure how to test it.
Any help appreciated.
Old Nov 7, 2021 | 05:09 PM
sov211's Avatar
You will get more accurate advice in the correct forum for your car (X350); this forum is for the previous generation (to 2003). But could it be a ground issue? The ground points behind the headlamps on the 350 tend to cause problems - they did on a 2005 XJ I owned.
Old Nov 7, 2021 | 05:46 PM
Thanks, I'll post this in the right forum.
jagent
Jun 5, 2022 02:18 PM
CBY335
Mar 9, 2021 09:57 AM
Arland Green
Aug 9, 2015 06:10 PM
XJRPro
Sep 23, 2012 09:39 PM
Yaguareté
Sep 8, 2012 06:33 PM
