03 VDP Misc. problems
Old Jun 1, 2008 | 12:59 PM
FactoryJaguarTech's Avatar
Default RE: 03 VDP Misc. problems
Sounds like you have a bad door latch setting off the alarm. Also probably a bad trunk latch microswitch.
You need to figure out which latch is bad. Lock the doors from outside with windows open and see if one of them doesn't lock or unlock every time.
Once figured out, you need to change it.
Old Nov 9, 2013 | 02:36 PM
odds's Avatar
Hi FactoryJaguarTech,
I have the same problem as the OP here. My 2003 XJR believes my "passenger door" is open the majority of the time. Sometimes, if I really slam it hard, the sensor reads it as closed. Whenever I wash the car or get it wet, the passenger door sensor always goes off. This is a problem because, when the electronics system reads the passenger door as open, it won't allow me to use the key dongle to lock it. Sometimes, since the car thinks the passenger door is open, it leaves the interior lights on overnight and drains my battery. A real pain in the ***!
All of my doors seem to lock and unlock fine, though my passenger door silver locking mechanism button doesn't seem to spring up as high as the rest of the doors' do.
Any ideas??
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
Dicque
Sep 19, 2015 12:53 PM
prettydaim
Sep 7, 2015 05:16 PM
Dicque
Sep 4, 2015 12:50 PM
