1998 timing chain tensioner
Old Apr 8, 2012 | 08:47 AM
ant17's Avatar
Default 1998 timing chain tensioner
How can I tell if the timing chain tensioners have been replace on my mom's 98 vdp? Without taking the covers off?
Carfax doesn't show a repair, but the water pump looks shiny new.
Car has just over 100K on it.
thanks
Old Apr 8, 2012 | 10:28 AM
Vector's Avatar
Someone posted on the forums here that you could put a small mirror in the oil filler hole in the cam cover to view the tensioner and if you could see "red" at the front end of the engine inside that meant that the tensioners had not been replaced.
I tried it, but could not see anything. I also know that the plastic sliders on even the new tensioners turn red with age, so this may not be a valid way of evaluating the replacement.
So, I think you are going to have to pull at least one cover to find out.
I have also heard about factory mechanics replacing only one tensioner and not both, so you should check both sides.
It's not a difficult or time consuming job, just make sure you replace the cam cover gaskets when you are done.
Vector
Old Apr 8, 2012 | 02:10 PM
orca99usa's Avatar
Changing the gaskets isn't a bad idea anyway. Just take them off and have a look.
RoyLittle0
May 25, 2023 02:38 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Bowman
Sep 15, 2015 06:54 AM
Bowman
Sep 3, 2015 03:17 PM
