1998 XJ8 REAR SHOCKS
Old Sep 5, 2007 | 05:23 PM
jag_genius's Avatar
Default RE: 1998 XJ8 REAR SHOCKS
first youneed the right tool ... the spring compressor... or some guys call it a widow maker...remove the rear hub 18mm bolt (mark this excentric bolt due to this being the rear toe adjustment)and a 22nut.. then lift then put to the right side(if doing drivers side rear)do not remove axle nut justpush to the side. there might be a washer that will fall out.. at the lower faulkrum bolt washer..tighten up spring then remove four nuts at top then remove lower shock bolt, then with your prybar and some strength...pry top of the shock out with spring.. then remove 17 mm nut at top shock .. then remove shock.. just remember how the bushings go...
Old Sep 6, 2007 | 10:16 AM
bigdreams05's Avatar
PLEASE! Make sure that you get the spring compressor, because that tool should be the widow preventer. Do this without the compressor and you will not have your hand afterwards.
jdzubas
Oct 4, 2015 09:14 AM
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
Busa R
Sep 3, 2015 05:01 PM
