1998 xjr engine reassembly
Old Sep 19, 2013 | 02:25 PM
mark bard's Avatar
Default 1998 xjr engine reassembly
Does anybody have a book or knows of anyplace i can get all the info needed to reassemble my engine. Timing chain replacement, heads, torque values,all that good stuff. I tried one of those mail order service manual on a disc, RIPED OFF.... Found a set some where but they wanted a $1000.00 for a 5 book set. No thanks. If any body can help Greatly appreaciated... You can call me at 1 519 682 0463 or e mail me at parkandbar@aol.com THANKS
Old Sep 19, 2013 | 02:55 PM
dsnyder586's Avatar
It's in here somewhere- I don't recall where, but others may chime in. AJ26/27 training course I believe it's called.
Old Sep 19, 2013 | 04:22 PM
avt007's Avatar
Do a search for JTIS on this forum. Download it and run it, all the info is there. I just did all the same work to my XJR using JTIS.
Also, this thread may help- https://www.jaguarforums.com/forum/x...-repair-97146/
Old Sep 19, 2013 | 07:21 PM
dsnyder586's Avatar
Also,could you give us a little background info on the motor/car?
May help us to give you guidance on what might also be amiss, as well as gotcha's.
Old Sep 19, 2013 | 11:16 PM
MoscowLeaper's Avatar
Get a JTIS and all information is there, but in the XK section.
Old Sep 20, 2013 | 08:47 AM
motorcarman's Avatar
The actual student guide I uploaded is ENGINE COURSE 168 V6/V8.
It is in the large file section somewhere.
bob gauff
Old Sep 23, 2013 | 11:29 AM
mark bard's Avatar
I tried looking for jtis and engine course 168 under this forum but it keeps coming back to my posts. Any help here locating the info i need.
Old Sep 23, 2013 | 12:46 PM
RJ237's Avatar
I just noticed that you are new to the forums, and that may be a problem as you need to have ten posts before you can download from the forum, if my memory is correct. Maybe a moderator will see these posts and explain better or even do an upgrade.
Meanwhile, please visit the new member area and introduce yourself. Link below:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
arnoldmilk
Sep 3, 2015 07:42 PM
OkieTim
Sep 2, 2015 12:48 PM
