1999 xj8 alternator replacement
Old Nov 9, 2013 | 10:48 AM
1999 xj8 fan's Avatar
Default 1999 xj8 alternator replacement
Can anyone suggest the best process ? I don't have a Manuel, I would appreciate any help. Thanks
Old Nov 9, 2013 | 11:11 AM
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center to X308 forum. Members here with the same model will be able to help.
PLEASE NOTE: the Jaguar Forums Advice / Feedback & Suggestion Center is for posts about the forum and NOT FOR TECHNICAL QUESTIONS.
Old Nov 9, 2013 | 11:19 AM
Thank you
Old Nov 9, 2013 | 08:40 PM
motorcarman's Avatar
Remove the air filter housing assy and alt mounting fasteners.
Jaguar warranty time is .8 hours (plus drive-in/drive-out).
It is NOT difficult.
I actually keep a rebuilt in stock as I am seeing alot more of these failing lately.
I RARELY replaced them when I was at the dealer but these cars are getting older.
bob gauff
Old Nov 9, 2013 | 10:15 PM
xjay8's Avatar
Hello Bob....so, you suggest it's OK to pull the alt. up rather than faff about underneath? ;o]
Old Nov 10, 2013 | 12:51 PM
You still need to disconnect/unplug from underneath a little I guess. I use a car lift so I am under and on top for most jobs.
bob gauff
Old Nov 10, 2013 | 01:07 PM
MoscowLeaper's Avatar
It's harder to pull it down.
Actually the only thing you need to do under the car is to remove an air duct. It is possible to disconnect an alternator while a vehicle is stanging on the ground.
-Disconnect a battery
-remove ait filter housing
-Remove radiator fans (don't mess with bolts - if you try to install a longer one you will damage a radiator. Actually an upper alternator bolt looks pretty much the same as a fan bolt, but a little bit longer)
-remove an air duct
-remove a belt
-loosen a lower alternator bolt
-remove an upper alternator bolt
-using a pry-bar, move an alternator away from engine and disconnect positive lead and regulator wires
-remove lower bolt
-remove an alternator
Reverse all of that for assembly
Old Nov 10, 2013 | 07:07 PM
Thanks Moscow Leaper
I really did not want to type all that out!!!!!!
bob gauff
Old Nov 10, 2013 | 07:42 PM
Since i was a JLR Russia technical trainer typing down a long and detailed descriptions was a part of my daily job, LOL
Old Nov 10, 2013 | 08:28 PM
Thank you all ! I received the new one today and plan on replacing it on Wednesday.... thanks
JarodL
Mar 7, 2024 01:39 AM
arnoldmilk
Sep 3, 2015 07:42 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
