2000 Jaguar XJ8 STAYS IN FIRST GEAR
Old Nov 4, 2018 | 10:23 AM
adainc's Avatar
Default 2000 Jaguar XJ8 STAYS IN FIRST GEAR
2000 XJ8 (64000 miles) has been fine for years. Stopped to fuel car and when I left station car hung up in first gear. Sliding the gear selector over to manual side of Jgate I could shift car thru gears. Transmission has been shifting perfectly the last 10 years. When in D it stays in first gear and when slowing down if you try to speed up you will get a catchup bump. feels like low trans fluid but you can shift it manually at least to gear 4. Summer use car only for us now but I need to fix. Transmission is dry and the car has no leaks! Any ideas... I understand the zf transmission leaves a lot to be desired. Another thing (no idea if it is culprit) the Jgate has resistance or seems to bind in the P-N-D area but is butter smooth on the manual side.
Old Nov 4, 2018 | 01:48 PM
Highhorse's Avatar
To start with, be sure to bookmark this... JagRepair.com - Jaguar Repair Information Resource ...you'll want to look up the transmission manual. There's a possibility it may be your rotary gear selection module.
Old Nov 5, 2018 | 09:54 AM
Samilcar's Avatar
Check for a stretched shift cable. It can cause those symptoms (stuck in first gear when cold in "D", but shifts normally while in "4").
Old Nov 20, 2018 | 12:47 AM
gears's Avatar
That is what mine did and it turned out to be the first drum/clutchpack. Very common at these transmissions. Lots of youtube info about this. So I did rebuild mine myself. Parts $215.00 Labor, well if I wouldn't have done it the car wouldn't have been worth it.
Jaguar-Russ
Jul 12, 2017 04:42 PM
Rogelio Serrano
Dec 2, 2016 03:59 PM
Eliskwirut
Mar 23, 2014 07:17 PM
mrtalkradio
May 16, 2013 02:19 AM
coldtater
Jan 12, 2013 08:42 PM
