2000 xj8 passenger headlight bulb replace
Old Feb 27, 2011 | 11:37 AM
belladad's Avatar
Default 2000 xj8 passenger headlight bulb replace
Does anyone know the procedure to replace the passenger side headlight bulb? I just received a call from my friend who has a 2000 model. I have a 2004 XJR.
Thanks for any help.
Old Feb 27, 2011 | 01:06 PM
JaguarXJR02's Avatar
I haven't done this in a while but if I remember it's not too difficult. If you open the hood I think you can see the back of the headlight housing, then there is the bulb wire and bulb "socket." I think you twist the bulb "socket" 90 degrees and then pull it out. then you have the bulb in the socket, to get the bulb out of the socket, pull on it. don't touch the bulb with your fingers, the grease on hands can shorten bulb life.
good luck
Old Feb 27, 2011 | 02:02 PM
belladad's Avatar
Thanks for the info. He is bringing the car by later today.
Kyle
MJ'S Jag
Nov 10, 2022 08:14 AM
rudelover2
Sep 11, 2015 08:53 PM
MarathonJohn
Sep 3, 2015 07:59 PM
kesslari
Aug 31, 2015 04:53 AM
Will P
Aug 27, 2015 06:52 PM
