2000 XJR Ash Tray
Old Dec 11, 2020 | 02:02 PM
jensenowner's Avatar
Default 2000 XJR Ash Tray
Good Afternoon All,
New Here But Have Had My XJR Since 2003. Have Taken The Console Out To Repair The Broken Ash Tray Cover. There Is A Spring That Operates The Cover And I Cannot Find Where It's Supposed To Go? It Was Not Attached When I Removed The Ash Tray From The Console. Can Anyone Please Help? That's All That Is Keeping Me From Reinstalling The Console Then I Can Start On The Broken Drink Holder.
Thank You
Wayne
Old Dec 11, 2020 | 05:21 PM
M. Stojanovic's Avatar
The ashtray spring should look like this:
It should sit at the side where there is a slot for the spring's "S" bend:
Old Dec 12, 2020 | 10:02 AM
O.K. Thank You I Take It That The Circular Goes Around The Stud But What Does The Straight End Attach To For Tension?
Old Dec 12, 2020 | 08:53 PM
The picture above is of my spare housing and I do not have the inner part (the cover) that opens and closes. The spring should be sitting over the stud of the inner part that goes into the hole next to the spring slot shown above and there should be a point (a small notch or stud) on the inner part onto which the straight side of the spring acts. As the spring was present when you removed the ashtray but it was, I presume, not operating the cover, it is possible that the notch/stud of the cover has broken off leaving the spring loose.
Barry_Tucker
Sep 19, 2020 04:49 PM
eliotb
Jan 26, 2020 02:27 PM
hisport
Apr 13, 2016 09:39 AM
metalmarty
Sep 10, 2015 01:44 AM
Pabarret
Jun 30, 2015 03:37 PM
