2000 XJR Transmission type and re-fill procedure
Old May 8, 2010 | 09:52 AM
river12's Avatar
Default 2000 XJR Transmission type and re-fill procedure
I have searched through some links and there is a lot of misinformation about whethere it is a zf or mercedes. I have no jag dealers around and have the filter..Just need to buy the oil and drain and refill. Any links or expertise on this matter?
Thanks for the help
Old May 8, 2010 | 12:20 PM
H20boy's Avatar
Pretty sure the 'R' on the earlier cars, were Mercedes.
I moved your thread to the proper XJ section, so you'll get a reply or two more shortly. When in doubt, ring your local Jag dealer, or if you want the oil and filter/gasket packages, try either Dan at Nalley Jag, or Ken at Motorcars Ltd, both are regular members of the forum, help out a ton on finding us the right parts, and Dan can even get jaguarforum members a discount on parts and accessories. Ken has a good deal on the fluid too, so I'll recommend you call him for sure for that. Its considerably cheaper than the dealer prices...nothing Dan can do about that.
Old May 9, 2010 | 11:09 AM
river12's Avatar
Thanks for the help and the re-post. I think your right, i have the merc tranny...all i need now is to make a dipstick tool.
Old May 9, 2010 | 11:55 AM
SuperSport's Avatar
You probably already know this, but here is one on ebay.
DipStick
Old May 9, 2010 | 05:52 PM
stran0020's Avatar
will that dipstick work on the N/A V8?? not the xjr
Old May 9, 2010 | 05:59 PM
test point's Avatar
Sorry, no. The ZF transmission fills through a plug in the side of the unit just above the pan.
stanjag
Dec 29, 2024 08:26 PM
MJ'S Jag
Nov 10, 2022 08:14 AM
rvdz
Dec 7, 2019 06:42 AM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
