2001 Jag XJR - Frozen Shift cable (Rust!)
Old Dec 23, 2019 | 02:07 PM
Nicdilla's Avatar
Default 2001 Jag XJR - Frozen Shift cable (Rust!)
Hello all. I need some advice, ideas...
I finally figured out why my shifter was malfunctioning. It was the shift cable. It was rusted or seized up tight. No longer moves. I have to say, it was another time I was PO'd at Jaguar Engineering on this. Why would thi be the case on a 2001?
Any ideas? Finding a new one is a joke. Finding a good used onenis also a joke. Can these be repaired and reused? Does anyone sell replacements for these "shoulda been recalled items"? I need to put this car back together.
Old Dec 24, 2019 | 10:34 AM
Highhorse's Avatar
Check with these guys... Jaguar Shifter Cable Xj8, Vdp 98-03 Xk8 97-02 MND4830AG, MJA4830AE - Jaguar Parts Specialist
Also, for local yards... Search Results
Old Dec 27, 2019 | 09:38 AM
grantorino62's Avatar
Years ago when I worked for a Pontiac dealer, we had a few seized shifter cables on Firebirds. Turned out to be a poor engine ground and the cable would act as the ground, eventually causing it to seize. Look for corroded/loose ground points regarding engine to frame as well. Widen your search to the west out of the rust belt.
Old Dec 27, 2019 | 06:00 PM
Robert Laughton's Avatar
Hi,
The XJR cable MAY be different. I know that the NA model has a rotary switch at the gearbox, and the R has a linear switch at the shifter end.
I notice from the JDHT site that the NA cable has suffix AA or AB and the R cable has suffix BE, BA BB
I really don't know.
Rob
poisonpill
Dec 10, 2023 03:17 PM
hermand
Jul 22, 2016 09:45 AM
Fieryhail
Nov 30, 2014 03:20 PM
rickysjag
Nov 26, 2012 07:30 PM
tony1963
Jul 28, 2012 03:26 PM
