2001 vs. 2002 XJR help.
Old May 5, 2011 | 09:40 AM
nicke's Avatar
Default 2001 vs. 2002 XJR help.
In the very near future, I will be signing papers on an XJR. My question is this: What are the inherant advantages/disadvantages of the 2002 model year as compared to the 2001?
Both cars that I am looking at seem to be in pristine condition, with low miles. Are there any specific things that I should check on either one? I have read all posts about the "typical" 98-03 issues, but just wanted specifics on these two models.
Thanks for your help!
Nick
Old May 5, 2011 | 11:07 AM
Sean B's Avatar
I've owned both and it's marginal - the steel liner engine is in both, but the metal tensioners are fitted to the 02' car, (IF it's got an engine manufactured after August 18/01), which saves a job to do. The 01' may have had the tensioner update, so it's something to check.
Both have the updated water-pumps, throttle body/cruise control systems too.
The thing is, I'm chatting about UK model years, not USA. I understand from this board, that the USA cars model years are 1 year behind, making them 00/01 (to me) - I'd need that fact confirming by one of our learned USA brothers before I can go into more detail.
Generally, later is better, all things equal.
Old May 5, 2011 | 01:57 PM
yeldogt's Avatar
I'm not sure if the 2001 has the CAT's suspension.
And the early 2001's may still have the water pump issue. The MB transmission was updated around 2000 -- so that would be the biggest concern.
Old May 5, 2011 | 06:20 PM
sparkenzap's Avatar
The US MY 02, XJ8 NA, built after the end of August, not only has metal tensioners, but a Morse style primary chain. I am not absolutely sure that the SC engine has the chain change, nor when it happened, but I believe the silent chain style primary chains is an important improvement.
Old May 5, 2011 | 06:38 PM
Boomer from Boston's Avatar
Is it known when the water pump changed? My XJ8 was assembled April 01.
Old May 6, 2011 | 10:02 AM
nicke's Avatar
All great information! Thank you!
way2far
Aug 31, 2022 09:26 AM
Dicque
Sep 19, 2015 12:53 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
adam699
Sep 12, 2015 05:32 PM
convincor
Sep 10, 2015 06:50 AM
