2001 XJR
Old Mar 1, 2025 | 08:38 PM
Bob Di Janni's Avatar
Default 2001 XJR
I'm considering remove cat. Anybody do this and what should I look out for. Want to increase HP. Factory is a bout 370 I believe. Maybe upgrade water cooling radiator or add oil cooler. I'll also change exhaust system to hopefully increase HP.
Old Mar 3, 2025 | 09:29 AM
mayhem's Avatar
Or just do a pulley change on the supercharger.
Car already has a factory oil cooler too. Intercooler water pump upgrade is a great idea of you're adding power.
Old Mar 3, 2025 | 10:54 AM
Addicted2boost's Avatar
You’ll likely need to upgrade the head gaskets next given the age they’re in prior to modifications.
Old Mar 3, 2025 | 12:34 PM
Parker 7's Avatar
Removing rear cats depends on if rear cat is aft of the rear O2 sensor and your final exhaust sniffer test to pass emissions
fwd cats must remain
The engine will regulate the same if rear O2 sensor is fwd of rear cats being removed
Old Mar 6, 2025 | 09:21 AM
DukeFonte's Avatar
Removing the cat can increase power but may trigger a CEL—O2 spacers or a tune can help. Upgrading the radiator and adding an oil cooler are good ideas if you push the car hard. A high-flow exhaust will also help with performance!
pcolapacker
Jun 3, 2021 10:07 AM
Srt42003
Jun 15, 2019 07:21 PM
Carnival Kid
Feb 8, 2019 08:42 AM
HSL8770
Jul 24, 2018 01:20 AM
Chuck08XJR
Sep 29, 2011 01:06 PM
