2001 XJR calipers
Old Oct 17, 2016 | 10:15 PM
Amphicar770's Avatar
Default 2001 XJR calipers
Hi all,
Looking at front calipers (non Brembo) but I see three different sizes 300mm, 305mm, and 325mm. Which is correct?
Thx.
Old Oct 18, 2016 | 05:54 AM
dwgates's Avatar
Default 99 non-brembo...
My 99 XJR non Brembo rotors were 325 mm...
Old Oct 18, 2016 | 06:03 AM
convincor's Avatar
for my 98, 305mm
https://www.rockauto.com/en/moreinfo...=1315903&jsn=1
https://www.rockauto.com/en/moreinfo...=1315903&jsn=2
Old Oct 18, 2016 | 01:58 PM
Mark SF's Avatar
My 2002 has 325mm.
Old Oct 18, 2016 | 06:36 PM
k-man's Avatar
I may be mistaken but I believe the Brembo equipped and Supercharged XJR use 325mm for the front end and 305mm in the rear, the XJ8 and non supercharged Vanden Plas use 305mm front and back. Never seen the 300mm's though.
Old Oct 19, 2016 | 07:30 AM
Daim's Avatar
I think the 300s were on X300 models. My front calipers and discs are from an X300 with 305 mm. So it can only be earlier models... Or the 300 mm is for the rear!?
Old Oct 19, 2016 | 12:45 PM
Thanks. the weird thing is that lots of places carry the left front (Centric part #14120012) but the right front #14120011 is essentially unobtanium.
Thanks.
Old Oct 23, 2016 | 09:36 PM
Johnny_B's Avatar
I'll correct you on that one... Brembo-equipped cars like mine actually have 355mm front rotors (13.9".) I seem to remember the rears being 330mm, which is larger than the front rotors on a standard XJR Amusingly enough, Autozone actually carries the 355mm cross-drilled rotors for the Brembo cars.. Not sure if they have the rear rotors or not.
Old Oct 23, 2016 | 11:37 PM
k-man's Avatar
Good to know, thank you.
kstevusa
Oct 25, 2016 12:37 PM
Geezer
Oct 17, 2016 06:19 PM
jbajor
Oct 17, 2016 11:23 AM
Paul Shashaty
Oct 17, 2016 02:39 AM
NSY
Oct 15, 2016 11:20 AM
