2001 XJR Original Tensioners?
Old Feb 5, 2019 | 09:13 PM
lyonsfin's Avatar
Default 2001 XJR Original Tensioners?
I am considering the purchase of a 2001 XJR. The VIN falls within the affected range. The car has 143K miles. Is it possible it still has the original plastic tensioners and guides?
Old Feb 6, 2019 | 02:26 AM
anduha's Avatar
The only true way to know if the repair records do not indicate a tensioner/timing chain upgrade is take the cam covers off. One side ought to confirm. 2001 had slightly stronger plastic tensioners but still fallible. If you suspect the parts are original 143K is well past time for an upgrade, change the chains, secondary and primary tensioners for worry free driving. Tons of how-tos on these forums for referral. If you wrench yourself kit and special tools can be had for under 1K. If it does not rattle on startup and has good compression go for if the car is in good shape.
chevre
Feb 14, 2017 06:48 PM
Andreas Schmieg
Nov 6, 2016 03:46 AM
thomash85715
Sep 26, 2012 10:32 PM
desp8838
Dec 24, 2011 08:03 AM
joel
Feb 27, 2008 08:18 PM
