2002 XJ8
Old Nov 6, 2016 | 08:24 PM
hairwolf's Avatar
Default 2002 XJ8
Brake lights stay on all the time. Third Eye goes turns on and off with brake pedal, like it should. Brake light switch on brake pedal seems to be working properly (but not sure) Any help would be appreciated.
Old Nov 7, 2016 | 08:02 AM
omgimali's Avatar
as what it seem it is a faulty Security Safety Locking Control Module (SLCM), that is in the boot/trunk beside the battery and under the fuse box. Make sure there isnt water near it as it can corrode the module
Old Nov 7, 2016 | 11:20 AM
Jhartz's Avatar
Most likely SLCM; are you getting any warning messages? May also be the brake light switch: also controls the cruise control -- is it working?
Old Nov 9, 2016 | 08:40 PM
Rpach10115's Avatar
Once again, this sounds like the SLCM..
Search SLCM and you will see lots of people have the same problem..
