2003 Jaguar XJR vaccum line diagram
Old Jun 13, 2014 | 01:47 PM
Ericbilt25's Avatar
Default 2003 Jaguar XJR vaccum line diagram
Hello, I'm a bit lost on the vacuum lines. Can someone help me with the diagram for the fuel pressure regular, MAP sensor and the bypass valve? Pretty much the entire vacuum line diagram. This is the only thing holding me back from starting up my new engine swap.
Old Jun 13, 2014 | 02:01 PM
Ericbilt25's Avatar
And also the TPS wire diagram for which terminal goes into the plug if anyone has that available.
Old Jun 13, 2014 | 09:09 PM
Ericbilt25's Avatar
I figured out the tps wire using a dvom, but I'm still stuck on the vacuum lines. I tried different routes and it starts and shuts back off.
Old Jun 19, 2014 | 10:51 AM
Ericbilt25's Avatar
can someone kindly walk over to their 2003 XJR and take a picture or tell me how the vacuum line for the bypass valve, MAP sensor is connected and where it goes too?
neruda
Sep 3, 2015 07:45 PM
big d
Sep 3, 2015 07:37 PM
BlacXJRcat
Aug 28, 2015 07:10 AM
Zues
Aug 27, 2015 12:02 AM
Terrance Williams
Aug 26, 2015 11:50 AM
