2003 XJ8 Engine Rebuild/Replace
Old Apr 3, 2016 | 03:16 PM
shimonek's Avatar
Default 2003 XJ8 Engine Rebuild/Replace
I have a 2003 XJ8 Sport with the AJ27 4.0 NA engine. Its a beautiful car... that I hope to be able to drive some day. I am hoping someone can point me in the right direction.
I purchased the car from a salvage yard with a low-end knock. I have the engine torn down and can see that the problem is a spun rod bearing. The bearing is completely gone and the crankshaft is seriously worn. The general consensus I get from reading the forum is that the engine is not worth rebuilding. The tensioners appear to be the updated metal version and are in tact, from what I can tell without removing the cover. I don't see any obvious scoring on the cylinder walls or cams.
I am looking for a donor car to perform an engine swap. I have read the threads on replacing a 4.0 with a 4.2 but have some questions. Since I don't have the SC and both engines use VVT, can I simply drop in a later model 4.2? Are there specific years/models that I should look for? Would anything from the 4.0 need to be reused? As I said, the heads look OK, but that bearing had to go somewhere.
Old Apr 3, 2016 | 09:16 PM
Highhorse's Avatar
Well, here's something to start with...JagRepair.com - Jaguar Repair Information Resource
It contains factory pdf's to TSB's along with some training videos.
Here's a couple threads to check, it does involve the 4.0, not the 4.2, but beefing up on a swap doesn't hurt....https://www.jaguarforums.com/forum/x...question-9301/ ...and... https://www.jaguarforums.com/forum/x...rebuild-97096/ (pay attention to what Plums says)
As for the engine swap, I don't have the knowledge on that and would have to review the link I gave ya. I would do a Search above on such or even an Advanced Search under the Tools tab. As for looking for a donor car or motor, check in the Marketplace above left in Member Marketplace, lotsa items for sale.
Personally, I'd take the crank down to a shop and have them mic' it to see if its toast or not...same with that rod.
Old Apr 4, 2016 | 01:39 PM
shimonek's Avatar
Thanks for the information Highhorse. I'll check out those links.
As far as the crank goes, I am confident that it isn't worth saving. It has a ~1/4 inch groove worn into it on the side with the missing bearing. I found a replacement crankshaft on ebay for a couple hundred dollars and was considering going that route. That's when I found the info on the 4.2 swap.
Old Apr 4, 2016 | 05:21 PM
Highhorse's Avatar
Oh c'mon, that 1/4" groove is an expanded oil journal for better flow....less oil pressure, but better flow...lol
Old Apr 4, 2016 | 07:24 PM
shimonek's Avatar
No micrometer necessary, my friend. I am definitely getting less friction from this cylinder!
2003 XJ8 Sport Worn Crank Journal
In one of the links you shared Disco1994 talked about getting his crank repaired for $120. I had thought it would be cost prohibitive. I'll have to make some calls.
Old Apr 4, 2016 | 09:49 PM
Highhorse's Avatar
Ewwww....yep, that is toast.
lenora38
Jan 28, 2023 12:17 AM
coachcrump
Mar 5, 2016 03:12 PM
L80ous
Feb 28, 2016 09:40 PM
Jonadesmond
Feb 28, 2016 02:00 PM
02jagstype
Feb 24, 2016 05:38 AM
