2004 xj8 engine overheating
Just purchased 2004 xj8 and engine is overheating. Replaced thermostat and water pump. Can’t see and leaks from hoses and do leaks underneath from radiator. Seems as if no water circulating to the engine. Any thoughts on what could be causing engine to overheat? Thanks
