2004 XJ8 no navigation system operation or radio
Old May 1, 2008 | 06:57 PM
FactoryJaguarTech's Avatar
Default RE: 2004 XJ8 no navigation system operation or radio
Likely you need a body harness. If the water has corroded the connectors and gotten into the wiring, you need to replace it. Not a great job, but likely nothing wrong with your nav or audio units.
Old May 1, 2008 | 07:02 PM
jag_genius's Avatar
have had it before.. you will have to remove fuse box and see how damaged it is if really bad needs a fuse box... and the connectors.. on the harness may have to be cleaned or pins replaced.. not hard just time consuming.. leave it any longer you will have more problems such as air suspension faults and alternator faults.. i had it on a car had alternator faults and the radio inop intermittently..
Dz1rfj
Jul 17, 2018 10:29 AM
jdzubas
Oct 4, 2015 09:14 AM
Dz1rfj
Sep 16, 2015 03:44 PM
TexasCat
Sep 8, 2015 04:36 AM
jimbo1948
Sep 7, 2015 03:14 AM
