4L80E-6L80E swap into XJR-8?
Old May 14, 2010 | 02:24 AM
THEhomelessONE's Avatar
Default 4L80E-6L80E swap into XJR-8?
I really want an XJR-8, but I don't trust ZF AT ALL! I have gone through too many of their transmissions, never again! Can I use the bellhousing from the XJR-6 or something similar to hook up a 4/6l80e to the XJR-8? Or would I need to have an adapter plate made? New to Jags, more of a Bimmer guy, so bear with me guys haha thanks!
Old May 14, 2010 | 03:20 AM
Cadillac's Avatar
As far as I am concerned bimmers come with ZF too . ZF seems to be a better tranny than MB's 7 speed ones .
Anyway, 4L80E may be one of the best tranny for 4 speed ones but being an XJ8 you have a 5 speed tranny .I don't know how to adapt 4 speed tranny and its electronics into a car that is made for 5 speed tranny .
BTW, why not use 4L60 E , those built rock solid and made for big RWD cars
Old May 14, 2010 | 05:32 AM
Jaxkr's Avatar
The XJR 8 for model years 1998-2003 is fitted with a Mercedes Benz thansmission.
Old May 14, 2010 | 02:08 PM
Exactly, BMW's have been all I ever drive, and I'm sick of the garbage ZF transmissions going out on me. So when I found out the XJR used a 4l80e I was pretty happy, but I really want to be able to swap in a 6l80e in the XJR8. 4l60e is weaker than the 4l80e, it does have shorter gears though. In America all the larger american SUV's have a 4l80e, most of the smaller v8's and v6's get the 4l60e. Well the transmission has an ecu of it's own and it can be made to be a standalone. I really want the XJR8, I'll just drive it until I have enough money for a 6l80e and swap that in, just need to know if there's a bellhousing off another jag I can use to bolt up to it, thanks for the help guys.
Old Jun 7, 2012 | 05:26 AM
Kiattisak Deelert's Avatar
have you succeeded with 6l80e swap?
let me know i feel the same way. but mine is xj-s v12 with 4l80e and i'd like 6 speed trans for her.
Old Jun 7, 2012 | 10:09 AM
Sean B's Avatar
that inquiry was over 2 years ago, and the original poster got it wrong, the XJR 8 uses a Mercedes trans, the 722.6.
Do you want a 6 speed manual or automatic fitted to the XJS?
Old Jun 7, 2012 | 04:15 PM
plums's Avatar
and the 722.6 is used in even heavier vehicles than the OP mentioned as justification for his preference, such as Sprinter vans and RV's.
Old Jun 7, 2012 | 10:11 PM
jagbush's Avatar
Actually I wanted to go manual but when i contacted drivenman, i didn't get enough info. they also cannot deal with pedal box for modern brake system.
Therefore, to save all the trouble I think I want to go for 6 speed automatic.
My jag is xj12 x300 with v12 6.0L, the tranny is 4L80E, so I think may be I can put the same family trans like 6L80E in with not much trouble. Any suggestion/comment?
studentper
Feb 20, 2016 09:43 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
millertic
Sep 30, 2015 08:11 PM
pnwrs2000
Sep 30, 2015 01:56 PM
Mark SF
Sep 28, 2015 01:51 PM
