98 Jag Engines-All Bad?
Old Mar 23, 2008 | 06:56 AM
wjgesq's Avatar
Default 98 Jag Engines-All Bad?
There is a lot of bad news out there re the 98 8 cylinder models. Something about the materials used in the engine. Are all these bad? If you have not had trouble by 64K miles, are they likely to surface?
Old Mar 23, 2008 | 07:15 AM
FactoryJaguarTech's Avatar
Default RE: 98 Jag Engines-All Bad?
If you can have a compression test done would be best way to tell if engine is worn. If it starts well and has no rattles, you should be fine.
Old Mar 24, 2008 | 12:12 PM
ken@britishparts.com's Avatar
You will hear a lot of complaints about the Nichsil liner of the cylinders. To be honest, we don't see lots of problems with these. The big culprit is the timing tensioners. If you hear a rattle at start up, shut it down and fix the car pronto.
Old Mar 24, 2008 | 03:40 PM
skanoski's Avatar
while we're on the 98 Nikasil issue.....my 98 XJR has over 130,000 with the original, Nikasil-lined engine. Apparently the Nikasil lining gets chewed up by high sulfur fuels - not a big issue now with most fuel being extremely low in sulfur.
my question is....does the Nikasil lining wear out faster with normal wear and tear, or is it more of an "all or none" issue with sulfur exposure? I'm wondering if I should expect a short life for my engine, or perhaps I'm in the clear. Anyone know how Nikasil lining holds up when sulfur is not an issue?
Old Mar 24, 2008 | 05:24 PM
jag_genius's Avatar
xjr engine are normally better and outlast the naturally aspirated... if the gasoline is really low in sulfur.. and is high quality.. and you don't make frequent stops in the cold with out letting the engine warm up.. and your battery is always up to snuff.then you shud have no problems..
Old Mar 24, 2008 | 05:34 PM
I'm with the Jag genius on this one. Don't sweat the Nikasil issue.
Old Mar 25, 2008 | 12:45 AM
The_Ikon's Avatar
I have overwell over140K on my 98 XJ8L engine and it is still purring!!! Now that tranny is another issue for me![]
Wolfy
May 28, 2024 08:06 AM
allenman85
May 10, 2021 03:11 PM
PMKimpton
Aug 3, 2019 08:22 PM
Rick Michael
Sep 6, 2015 06:53 PM
edtexas
Sep 5, 2015 10:49 AM
