98 positive cable replacement
Old Mar 2, 2013 | 04:26 PM
98jags's Avatar
Default 98 positive cable replacement
Hello everyone, I was wondering if anyone had advice on replacing a burnt positive cable that's located under the bonnet. I am not really mechanically inclined so, any help would be apprieciated. This was recommended by my local dealer to correct a starting issue. Battery charge is good, just wont turn over.
Old Mar 4, 2013 | 05:46 PM
fredd60's Avatar
Default positive
Hi 98jags, we need a bit more information regarding which cable you need to replace. A couple of photos would help.
Old Mar 5, 2013 | 09:17 AM
98jags's Avatar
Thanks for the reply. It appears to be the cable that runs from the boot up to the pos cable post(?) under the bonnet. I was quoted $600.00.
Old Mar 6, 2013 | 08:34 AM
xjrsteve's Avatar
If you measure the lenght of that cable, any car audio shop can make for you a good quality and thick cable. They use oxigen free copper cables, that could be better than the factory one, and way cheaper.
My starter even runs faster since I installed one more thick ground cable between the battery and the body in the trunk. I connected it to the ground screw next to the factory main ground point screw.
Old Mar 6, 2013 | 12:02 PM
98jags's Avatar
Thanks, I will try that and let everyone know how it went.
JarodL
Mar 7, 2024 01:39 AM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
