98 XJR brakes pads dont fit
Old Jun 15, 2015 | 09:27 PM
mustangtyson's Avatar
Default 98 XJR brakes pads dont fit
I have standard brakes. Let me start off by saying that i have the correct replacement rotors. I measured the old ones and the new and they both show 28mm which is what my manual shows they should be.
I have compressed the brake caliper with this lang 279 tool.
Amazon.com: Lang Tools 279 Brake Caliper Press: Automotive Amazon.com: Lang Tools 279 Brake Caliper Press: Automotive
They are compressed even with the metal lip inside the caliper and the only way to further compress them would start smashing the rubber seal.
I believe this is a pad issue. I have a new set of Wagner MX394A pads. They look correct and fit into the caliper but are too thick to fit over the rotor. I measured each pad (backing plate and all) and both were 20mm thick.
Does anyone else have a set of pads that fit a 98 XJR? Could you measure how thick yours are new?
Old Jun 16, 2015 | 10:49 PM
Update. Purchased a second set of pads. Just the cheap autozone ones. Guess what, they fit perfectly.
They measure 17mm thick including backing plate and anti-vibe shim.
So now I need to order brake pads from a company that makes quality pads and knows the correct thickness to make them as Wagner does not know and is distributing 20mm pads.
Old Jun 17, 2015 | 02:19 AM
xjay8's Avatar
Don't waste time and money on crap pads....fit Akebono...straight outa the box ceramics ;o)
Old Jun 17, 2015 | 04:52 PM
Jhartz's Avatar
Take them back to the store where you bought them: the clerk sold you the wrong pads.
My wagners fit just fine. But after the clerk at Advance Auto gave me pads for a normally aspirated Range Rover Sport, instead of a super charged one: I double check the part number.
Old Jun 17, 2015 | 07:42 PM
On your XJ8 did you get the ceramic or the metallic wagners? Were they the same part number as mine?
Old Jun 18, 2015 | 04:26 AM
Jhartz's Avatar
Don't remember; 28 months ago: Wagner's Gold or best series.
Old Jun 19, 2015 | 09:15 AM
Ordered
Akebono EUR394A EURO Ultra-Premium Ceramic Brake Pad Set
Amazon.com: Akebono EUR394A EURO Ultra-Premium Ceramic Brake Pad Set: Automotive Amazon.com: Akebono EUR394A EURO Ultra-Premium Ceramic Brake Pad Set: Automotive
Old Jun 23, 2015 | 08:15 PM
update: pads fit great Akebono EUR394A
Forcedair1
Sep 8, 2025 01:57 PM
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
philwarner
Sep 6, 2015 11:10 PM
