98 XJR Shuts Down After Start
Old Sep 17, 2023 | 09:25 PM
Excalibur2012's Avatar
Default 98 XJR Shuts Down After Start
40 PSI Fuel Press at the rail. Engine starts, Fuel pressure immediately drops & engine dies. Thoughts ?
Old Sep 17, 2023 | 11:39 PM
M. Stojanovic's Avatar
When the ignition is switched "on", the Pump 2 will run for 2 sec. and prime the system (to ~40 psi). On engine is start-up, the Pump 1 will run to supply fuel. The Pump 2 will later be switched "on" if there is higher demand for fuel (hard acceleration or high speeds).
It seems that your Pump 2 is good but Pump 1 (or its relay) is bad.
Old Sep 18, 2023 | 08:22 PM
Default X308 Run Issue
Great response !
Asking for a friend who had the start / run issue & a heart attack about the same time. He's in recovery, so it may be a few days before he's in shape to check it out.
Thanks !
QUOTE=M. Stojanovic;2679568]When the ignition is switched "on", the Pump 2 will run for 2 sec. and prime the system (to ~40 psi). On engine is start-up, the Pump 1 will run to supply fuel. The Pump 2 will later be switched "on" if there is higher demand for fuel (hard acceleration or high speeds).
It seems that your Pump 2 is good but Pump 1 (or its relay) is bad.[/QUOTE]
BlueXJR
Jul 20, 2023 06:22 PM
EnglishTerry
Jul 6, 2023 11:44 AM
David7
Oct 6, 2017 10:02 AM
moff1959
Dec 6, 2015 04:27 PM
Jaguar_Guy510
Apr 20, 2013 03:40 PM
