99 XJ8 Headlight Lens Replacement
Old Apr 10, 2010 | 06:23 PM
IcyBlueRose's Avatar
Default 99 XJ8 Headlight Lens Replacement
Today I discovered the inner lens on my passenger side headlight has been busted (probably a rock?). The entire headlight assembly costs at least $300. I essentially just need the glass replaced. I found some parts stores that sell a "headlight lens," however there are no pictures. Is this part what I need? If so, does anyone have any tips for the install? The link listed below is the part I'm looking at.
http://www.partsgeek.com/catalog/199...ight_lens.html
Thanks!
Old Apr 10, 2010 | 07:33 PM
Markus's Avatar
You could try this: http://forums.roadfly.com/forums/jag...8064158-1.html
Cheers!
Old Apr 10, 2010 | 08:34 PM
Default RE: Headlight for $17
Thanks, that is a great idea, however the lamp talked about in that post is no longer manufactured. Does anyone have another idea for an almost identical lens that could be used like in that post?
I still need to know if that part I was asking about will work. Anyone?
Thank You!
Old Apr 11, 2010 | 12:11 AM
Sarc's Avatar
@IceBlueRose
I ordered the same part from parts train. It is in fact the lens and the reflector in one unit. To me it looked exactly the same as the 300+ one I saw at the dealership. I fitted it myself and it looked exactly the same as the one I took off. I would buy this part with confidence
While you're at it, you may also do a search on this forum for headlight protectors..... there was a good discussion on those, and it seems for around 50~60USD you can get a kit for the XJ8 that was highly recommended by a few forum members here.
When you think about it, you have almost 700USD worth of headlights, so spending 50~60USD to preotect them seems like a good idea
Old Apr 11, 2010 | 03:04 PM
Default Thanks!
Thank you, I can now buy this part with confidence. And I will look into the headlight protectors.
Thanks so much.
JarodL
Mar 7, 2024 01:39 AM
arnoldmilk
Sep 3, 2015 07:42 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
