99 xj8 pcv problem
Old Feb 17, 2008 | 10:19 AM
steve's Avatar
Default 99 xj8 pcv problem
Hi does anyone have a copy of the tsb for the clogged l/s valae cover
Old Feb 17, 2008 | 10:27 AM
jag_genius's Avatar
Default RE: 99 xj8 pcv problem
not on me.. website is down.. you just pop the hose off d/s and with mechanics wire or a drill bit.. stick it in and make sure it is not clogged up
Old Feb 17, 2008 | 09:32 PM
ibjags's Avatar
Ive been using the end of antenna mast for years
same diameter as whats called for and no worry of drill bit falling into cam cover
Tony at Jag school thaught i was nuts till he mic"d the diameter and it was the same as whats called for for in the TB
Old Feb 18, 2008 | 06:20 AM
FactoryJaguarTech's Avatar
Lol I would have called you nuts too. If tony says ok, good enough for me!!
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
jdzubas
Oct 4, 2015 09:14 AM
jimbo1948
Sep 7, 2015 03:14 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
