99 xjr won't start
Old Jan 15, 2014 | 01:29 PM
buttercup26's Avatar
Red face 99 xjr won't start
Wife drove car to work and 8 hours later the car won't start. When the key is turned we here one click then nothing. All lights, controls, radio, and heater fan function. I tried jumping with cables and also a booster pack with the same results. I'm guessing the starter (or starter solenoid relay?), yet since this vehicle is new to us wondering if it is something simpler. Car has 69k miles.
Old Jan 15, 2014 | 03:13 PM
RJ237's Avatar
It's possible that the connections to the starter are in need of cleaning, same for the engine to chassis ground strap. When the key is turned to start with the lights on do the lights go dim, or stay bright? There are many power and ground connections in these cars, and they can cause trouble with age.
Old Jan 15, 2014 | 07:00 PM
avt007's Avatar
Connect your jumper cable between the exhaust manifold and the bolts on the shock tower. Basically your are adding another engine ground strap. If it starts, drive it home like that (make sure the jumper cables are carefully stowed under the hood) then get the ground strap replaced.
Old Jan 15, 2014 | 09:15 PM
motorcarman's Avatar
Check for the burnt connector on the 'false bulkhead'.
The starter/alt wire bolts on there and gets loose/melts.
I see this fault often enough that I keep a spare on the parts shelf.
Also check the MEGA FUSE connection in the boot near the battery.
bob gauff
Old Jan 16, 2014 | 12:20 PM
Thank you, I will try these all and post results.
Old Feb 20, 2014 | 07:08 AM
Default repair progress
After getting it home, a friend tapped the starter while checking the connections and it started. Took his advice and replaced the starter to be on the safe side. Now a month later went to start her and the same thing as before just a click. Came back to my original post to reference what advice to now quadruple check. Guess what I neglected to check all along. The connector at the bulkhead. All that wasted time for a simple fix.
JarodL
Mar 7, 2024 01:39 AM
hunter34
19
Sep 14, 2022 11:09 PM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
