99'XJR-Blown head gasket
Old May 12, 2010 | 12:45 AM
dmr's Avatar
dmr
Default 99'XJR-Blown head gasket
This car didn't overheat. Ran for only 15 mins before I shut it off...started again and white smoke. A week earlier it had a slight coolant leak...needed two thermostat hoses...fixed and all was good. drove car for about a week...another 150 miles or so no probs. No engine lights. Then one morning low coolant light on again. Drove car a few blocks and NEVER got hot..not even to normal temps. Shut off car. Started and white smoke. SHut off again and froze. No crank. Now it apparently needs a head gasket.
What should I expect to pay? assuming all else is OK? Is a used xjr motor better option? Will a 2004 engine mate up to this trans?
Thanks for your help
D
Old May 12, 2010 | 08:58 AM
JimmyL's Avatar
Default Blown head gasket
I'm not saying it's not the head gasket, but I would be sure of the diagnosis before going too far. A head gasket leak will not cause a "no crank" situation. If the engine will not crank over at all, there's something else amiss. If the engine is siezed up, then you probably will want to think about replacing it.
Old May 12, 2010 | 09:07 AM
H20boy's Avatar
The no start is not related to the head gasket. Smoke indicates one possibly, but the no start sounds like cylinder wash. It happens on those engines. Read up on it here.
Old May 12, 2010 | 10:18 AM
dmr's Avatar
dmr
Default Hey Thanks
For the input.
Old May 12, 2010 | 11:02 AM
H20boy's Avatar
you bet dmr, good luck and follow up when you get a positive outcome
X308XJR
May 20, 2019 06:50 PM
kthrash
Feb 25, 2019 10:20 AM
Pontsu
Oct 1, 2015 09:56 AM
Woznaldo
Sep 26, 2015 11:02 AM
BSM
Sep 25, 2015 05:00 PM
