ABS control module removing & brake bleeding
Old Feb 27, 2013 | 11:41 AM
sergey.v.klimov's Avatar
Default ABS control module removing & brake bleeding
I need to remove ABS control module from 1999 XJ8. I found this instruction: , so I have to remove 4 brake lines from ABS pump first. Instruction says nothing about brake bleeding, but my repair manual says that you need to bleed your brakes (but they remove whole assembly (pump and control module), i just need to remove control module). What should I do?
If I do this:
am I going to lose some brake fluid? Do I need to after/before brake bleeding? Do I need to do something special with brake pedal prior that removal?
Old Feb 27, 2013 | 11:57 AM
Brutal's Avatar
You dont remove the lines. Unbolt the assembly and bend the lines to gain access to the ecu bolts. Then put it back together and bend them back. You know they were bent to make them so they bend easily to get them out of the way.
Old Feb 27, 2013 | 12:01 PM
What do you mean "unbolt the assembly"? Just to do that step, without removing brake tubes before?
Old Feb 27, 2013 | 12:23 PM
Sean B's Avatar
No, Brutal means remove the module from the side of the pump after making space to do so by bending the brake lines.
Old Feb 27, 2013 | 12:25 PM
I see. So I dont need to unbolt mine brake lines, i just need to bend them. Thanks
Old Feb 27, 2013 | 03:22 PM
Brutal's Avatar
yes, but unbolt the 3 10mm bolts that hold the whole assembly to the car to be able to move it around
Jpav27
Jul 31, 2022 06:43 AM
PMKimpton
Aug 3, 2019 08:22 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
XJsc-guy
Sep 25, 2015 11:09 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
