ABS tone wheel removal?
Old Nov 1, 2018 | 06:07 PM
dwgates's Avatar
Default ABS tone wheel removal?
I added this on the end of one of my earlier related posts but am now thinking I should have just started a new thread...
OK so I found some spare front knuckle assys on ebay. They arrived today along with the bearings I picked up on amazon. I got the little torx bolts out of the splash guards so they'll be free once the pressing starts. Now I want to break the ABS tone wheel free before heading to the machine shop for the hard stuff. I've found a few threads mentioning a 12 pt socket being an acceptable substitute for the special tool but the one thread I found mentioned a 2" socket. It seems like my 2-1/8" socket is a better fit on the wheel. I think I'd have to pound the 2" socket into place which doesn't seem right. With the hub in my vise I've been able to exert quite a bit of force (not 330 N-m yet) but then the vise starts letting the hub start to spin. Since I don't have the ability to hold the hub from spinning in my vise while I'm applying force thru my 3/4" ratchet I'm planning on letting the PB blaster I soaked everything with work overnight and tomorrow I'll take the spare out of the trunk and use the inertia of the wheel against my impact driver and see if I have any luck. Does anyone remember if that 2-1/8" socket was the one they actually used? It's loose but seems to grip the wheel so I think it will be ok but I thought I'd check and see if anyone remembers from their job.
Old Nov 1, 2018 | 07:50 PM
RJ237's Avatar
I do believe it was a 2", but I have the official tool so I can't be certain. I removed mine by drilling the benchtop for the wheel bolt pattern and bolting the hub to the bench. Then a couple of friends steadied the bench while I broke it loose.
Old Nov 1, 2018 | 08:08 PM
motorcarman's Avatar
Any Chevy 5 on 4 3/4" wheel bolted to the hub will hold it in place.
Air Impact is a better choice for loosening the hub nut.
I actually bought the 'lolly-pop' JD227 Hub, holding tool and Special Tool 206-066A when I worked at the dealer because they were always missing from the tool room.
The Special Tool 206-066A should be modified for the later cars. TSB 100-35 describes the problem with the ABS rotor nut 2005 MY-ON XKR VIN A41332-ON.
ADMIN TSB 1-78 describes Essential Tools.
bob
File Type: pdf
File Type: pdf
Old Nov 5, 2018 | 06:51 PM
dwgates's Avatar
Wahooooooooooooo! The ABS tone wheels are off! I had the hub attached to my spare and had levered the wheel against my work bench and a 2x4 that I'd wedged between the front and back legs. I wrapped a rope around the tread 3x and used a couple of bowlines to simulate a block & tackle to make sure everything was tight. Then I put a 5' pipe on my 3/4" drive with a 2" 12 pt socket. I was pulling with everything I could muster and the thought occurred to me that if anything let go (not that the tone wheel even gave me a hint of movement) or worse, slipped off the rounded projections on the top of the tone wheel it would be bad. I went to u-tube and found a review of a 20v lithium battery powered impact driver that harbor freight sells which claims to produce 1200 ft-lb of break away torque. picked it up on my way home from work today, charged the battery for an hour and it didn't even break a sweat! My air impact claims 450 ft-lb but that wasn't even touching those nuts! Now it's off to the machine shop for new bearings in my spare hubs than onto the old cat once I get enough good weather to do the quick swap. Always a good feeling when a car project yields to your will! Thanks again for the help on this one.
Old Nov 5, 2018 | 07:12 PM
RJ237's Avatar
Sounds like another Lake Ontario sailor putting experience to work. I'm going to have to check that impact driver.
Old Nov 6, 2018 | 09:15 AM
CharlzO's Avatar
I might have to look into that 20v for when the corded 1/2" harbor freight impact I have dies someday. Cheap as it was, and as lowly rated, but that broke my ABS rings free (with some steady hammering for a good minute) when a highly rated air impact couldn't. I always treat my HF stuff as disposable but be dammed if sometimes they don't just up and surprise me sometimes!
Glad you got it off!
aholbro1
Feb 22, 2011 10:56 AM
chrisfinch
Oct 11, 2009 11:28 PM
Mr_Miami
Aug 22, 2008 12:50 PM
rekogniz1
Mar 27, 2008 04:42 PM
