Accessing a locked trunk in a 1998 XJ8
Old Oct 24, 2013 | 08:24 PM
EChem's Avatar
Default Accessing a locked trunk in a 1998 XJ8
Hi all:
My friend locked her key and fob in her trunk. Currently utilizing the valet key. What is the best way to get in? Removing the rear seat? I have downloaded the JTIS software, but can't seem to find info on how to remove the rear seat in JTIS (and if I can access the trunk this way). Or is there another way. Someone suggested running a hot wire from the fusebox and I may be able using it to trigger the trunk release mechanism, but was unsure of the particulars.
Old Oct 24, 2013 | 08:53 PM
Lear45's Avatar
Do not remove the seat. The gas tank is behind that.
If you remove the license plate and the nylon blind nut on the right upper you can get a long thin screw driver up to the latch. A flex head flashlight like this will help.
LED Flashlight, Greenlee FL2AAF Flexible LED Flashlight | Meritline.com
Don't cut or break anything. It is a 20 minute job the first time. Going forward, get a spare real key. $150 at the dealer.
Old Oct 25, 2013 | 05:26 AM
EChem's Avatar
Dear Lear:
Thanks for the help. Will try this Sat. after work or Sunday. At least the valet key was able to start the car and drive home (after a 2 hr. drive to get to them, lol). Was afraid with the security system activated, the valet key wouldn't start the car.
EChem
Old Oct 25, 2013 | 03:17 PM
70z28's Avatar
Is there not a button inside to pop the boot my jag has 1 on the dash
Old Oct 25, 2013 | 04:40 PM
avt007's Avatar
If it's your only key, then you can't get in the car to pop the trunk. I did something similar once. On my car I went through a hole on the bottom left with a long narrow screwdriver and was able to pop it that way.
dsnyder586
Dec 29, 2024 07:39 PM
DrTripp
Mar 22, 2020 09:33 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
XJsc-guy
Nov 23, 2015 01:56 PM
speacock
Sep 10, 2015 12:14 AM
