add a 4th interior grab handle
Old May 19, 2013 | 07:05 PM
JaguarXJR02's Avatar
Default add a 4th interior grab handle
I randomly got the idea the other day to add a 4th grab handle to my interior. the holes you need are in the bodyshell, the only challenge is cutting holes in the trim panel.
My steps:
1. use masking tape to approximate where you need to cut
2. measure the size of the needed holes (about 3cm wide and 1.5cm tall)-this is based on the hole size in the passenger side trim
3. use a pen to mark your approximate cut area
4. use a box cutter to cut out a square of the 'leather' trim that covers the a pillar panel
5. use a drill with a rather large bit and files to square out the hole
6. done: re-install panel and screw in the handle
my hole cuts weren't perfect the first time, I had to go back and trim out some more plastic.
done: I bet I'm one of the only X308s with 4 grab handles!
Attached Thumbnails add a 4th interior grab handle-58f67bdc-9a68-4649-a206-8e7f679c72b9-12499-0000062ef56169b7_zps1ba81602.jpg   add a 4th interior grab handle-93438134-0edf-40c7-b4c8-0ad03b5748fa-12499-0000062effa441a4_zpsa5dd06d3.jpg   add a 4th interior grab handle-3e37be05-dc6a-49e6-8365-9dcb849fb026-12499-0000062f0e9f48f3_zps035a8ae4.jpg
Old May 19, 2013 | 07:40 PM
Azcat's Avatar
Nice work!
Old May 19, 2013 | 08:35 PM
mechelement's Avatar
Nice mod. Do the other handles have pem nuts holding them on to the body? Are yours fastened with self tapping screws?
Old May 20, 2013 | 09:14 AM
Sean B's Avatar
All bodyshells are equipped with threaded mounts for either lhd or rhd. Bolts are torx.
To be honest, why have the 4th, isn't the steering wheel enough to hang onto, or have you fitted the apple iphone 'steer 4 u' app lol!
I'm glad Jaguar never fitted it drivers side as I bump my head on stuff like that. I guess it gives the other half foot rests!
who's Jag's got high heel marks in the roof lining?
Old May 20, 2013 | 10:53 PM
hahahahahahaha
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
1964Daimler
Sep 9, 2015 11:28 AM
